Old 11-30-2008, 10:31 PM
5-7HEAVEN 5-7HEAVEN is offline
Default Re: The Happy Time Teardrop Tank Is Not Flowing.
Hooray for the primer bulb!
Without the bulb plumbed right below the filter, I'd be siphoning gas to both tanks. Squeezing the bulb, it takes a few minutes to fill each tank on flat ground. No need to run the bike up the tree anymore to fill gas every 10 miles.
Still a lot of air in the system. First I'll remove the brass elbow, run a straight 1/4" fitting and insert the 3/16" steel line and a 6" hose.
The extra parts are laying around somewhere, and will save me another $15.
If that doesn't work well enough, I'll drill the tanks and install vents.
