Thread: chain tension
Old 04-08-2013, 10:44 PM
ResetBTTN's Avatar
ResetBTTN ResetBTTN is offline
Default Re: chain tension
I've heard that half links will take out that slack. It was an option of mine before I realized I could just slide the tire back. Easy fix. I would try that first and if it works you may not even need the tensioner. I didn't wanna use the pulley that came with my kit. Couldn't and wouldn't fit on my seat stay or chain stay to be used anyway. I use a heavy duty size 41 chain...anything less than that my 80cc has broken the link or snapped the chain in half.
I'm not a welder either so I cant help you there. If you won't miss your eyebrows then weld away lol.
{~If at first you fall off just hit your ResetBTTN~}
