Thread: chain tension
Old 04-08-2013, 09:54 PM
ResetBTTN's Avatar
ResetBTTN ResetBTTN is offline
Default Re: chain tension
Are you able to slide your rear tire back? What's your cycle? I have an OCC Schwinn Chopper and I had a chain tension issue and it was solved after just loosening the rear tire bolts and sliding the tire back until the chain was as tight as it could be. Locked the tire back down and BAM! No more prob.
{~If at first you fall off just hit your ResetBTTN~}
