Thread: bogging down
Old 11-29-2008, 11:53 PM
Motormac Motormac is offline
Default Re: bogging down
Jim, I see where you are going with this and its great to help out a newbie with this kind of problem. This is something I deal with all the time and would like to offer a suggestion if the heat method fails. I will use a Dremel rotary tool and using a cutoff wheel cut a slot into the broken stud, then with a slotted screwdriver the same size as the broken stud and a pair of vice grips firmly clamped on the screwdriver give it a strong tug. 99% of the time this works. just a suggestion if all else fails. MAC
