Old 04-01-2013, 12:21 AM
Legwon Legwon is offline
Default Re: speedometer computer
Originally Posted by maniac57 View Post
Just be sure the magnet is close to the pickup...that's the 6cm measurement, (should be 6MM) It does not matter where you mount it as long as it is close to the pickup as the wheel spins.
actually is 1.5mm max spacing between magnet and sensor :s tight fit.
And look for the little arrow on the sensor. The magnet on the spokes should line up exactly with that arrow. Otherwise your speedometer won't work well.
right, ill have to look at that .
