Old 03-22-2013, 08:13 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: best beach cruiser to use?
The "best " should be the bike YOU like, what I did on my first bike I found a frame type that would work with the engine kit in the color I wanted. Many will tell you to avoid aluminum frames but I have over 1000 miles on my o.p. cruiser with no frame problems. I also have a huffy cranbrook, it rides smoother but is heavier so I have to pedal more. So I say find a bike that the engine will fit in that you like and get started. No matter which you choose you need to add a front brake, the coaster brakes alone are not enough.
Your results may not be the same,Greg
