Old 03-16-2013, 10:38 PM
Nehmo Nehmo is offline
Location: The Slum of Kansas City, Kansas, United States
Default Re: Prop Bike Trailer - Suggestions?
Originally Posted by maniac57 View Post
A shroud would have to be quite heavy duty construction to contain a spinning prop.
The prop spins without touching the shroud. Are you saying the shroud should be bullet-proof, able to withstand a catastrophic failure of the prop?
Be aware of the dangers and do your homework on design first.
In order for a shroud to improve thrust, there has to be super precise tolerance on the blade to shroud clearance.
Actually, the ducting-trust-improvement was a secondary possible benefit of the shroud, but I'm certainly interested. Do you have any information on the effect of varying the size of the margin between the inside shroud diameter and the prop diameter?
