Thread: bogging down
Old 11-26-2008, 10:47 AM
squire squire is offline
Default Re: bogging down
well its getting there, still have promblem with the motor bogging d
own at full throttle. it seems that i have gently work the the throttle
until i get to full speed. then i can pull it all the way.. also it seems to run a little better if i leave the choke on half way? and it dosnt want to cut off if i give it full choke!...... took it around the block..checked the plug and look fine but noticed a small amout of oil on the plug is that normal?
man i cant thank you guys enough..
