Old 03-06-2013, 08:02 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Need advice on Oil mixture
Originally Posted by Shobiz1492 View Post
what kind of grease should i use for the gear that goes into the motor, it sounds like it should be greased up a bit cuz it squeeks when ever i pull the clutch
The bar inside the clutch cover needs grease.
(It's in the center of the drive sprocket)
Pull it out and grease it well and squeak will stop.
