Old 02-24-2013, 12:00 PM
curtisfox curtisfox is offline
Default Re: how to lengthen steerer tube on a bicycle
Originally Posted by bairdco View Post
i just did the same thing yesterday...
i had an old fork from the 30's i wanted to use on a bike, but the steer tube was really short, like 4".
i chopped up another fork from the junk pile, and welded in an inner sleeve, then put an outer sleeve over that. luckily, i figured out the bearing race had to go on first, as the outer sleeve is just small enough to allow the bearing to clear.
i double sleeved it because i'm making a really fast bike, and the last thing i want is a broken fork at 50+...
7/8" cold roll fits in them nice and tight if you realy want to stiffen them, also you can use the cold roll to streighten them helps keep it from flatening the tube if you put it in a press..............Curt
