Old 02-19-2013, 09:00 PM
mombo390's Avatar
mombo390 mombo390 is offline
Default Re: Twin Engine Rack Mount
Thanks guys, the reason im going with a twin engine setup is because i have the engines already pulled them off my uncles weedeaters and they are identical models. I also fabbed the mount to have 9 inches of rack width to play with. so im assuming if i mount one engine further back and get that to drive the live axle of the engine which has the clutch that would work? I dont think sproket alignment would be much of an issue. Also are there any brands of clutches you all would suggest that has a built in sproket?
I forgot to mention that the crank shaft of the engines is threaded where the original clutch was so how would i get the bushing to fit?
Appreciate all the help im 17 and this is my first project so input from all you experienced folks is greatly appreciated
