Thread: help
Old 01-11-2013, 08:43 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: help
The timing is done by the magnet on the crankshaft end, if you didn't remove the magnet that is probably not the problem. Do you have fuel in the carb bowl? If you choke it fully does the spark plug show signs of fuel when you remove it?
Your results may not be the same,Greg
