Thread: kill switch
Old 11-16-2008, 03:04 PM
toytime toytime is offline
Default Re: kill switch
Most if not all small engines "kill" power by grounding the mag. so I've never understood that thing about burning out the mag by using the white wire to kill the engine. i hooked kill switch to white wire and grounded the other kill switch wire right under the switch itself with a two inch wire. No need to worry about what wire you use from the switch.
