Old 11-15-2008, 12:45 AM
hiker472's Avatar
hiker472 hiker472 is offline
Default Re: Throttle useless
Another problem I had was when I was installing the kit itself. The cable for the carb came preassembled, so I never gave any thought to actually making sure it worked right. After hooking up the cable to the throttle handle something didn't seem was way to tight. If I had left it, my carb would've been stuck wide open.
What I did was shorten the casing on the cable by an inch and that solved that problem.
How is your cable?
