Old 11-30-2012, 10:29 AM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
Default Re: gas tank giving me the blues
Take it to your local muffler shop and see if they can weld the studs for you again. That would seal it better and if you used a tank sealer on the inside it should be fine after that. Just make sure you don't try to over torque the nuts when you install it the next time. If you over torque the nuts they will make the studs leak at the tank again.
