Old 11-12-2012, 07:47 AM
dracothered's Avatar
dracothered dracothered is offline
Default Re: Working with copper
Originally Posted by Tool Maker View Post
You can't.
If you want the end product hard, beat it in to submission as-is. The only way to harden copper is to work harden it. Added cold work will make that coupling even harder.
Ok do you think it will work harden enough when I flatten it out so I can make the flange? What about thickness, should I try to bend a lip around the outside edge to stiffen it?
