Old 10-28-2012, 03:14 PM
bigbutterbean bigbutterbean is offline
Default Re: Need help with repair
If Liquid Wrench loosened the piston, then it was stuck to the cylinder. Spraying liquid wrench around the piston would not loosen anything in the crankcase (bottom end). Sometimes pistons become stuck and they are not completely seized. If you added oil and gas to the tank separately without mixing it first, that could cause the piston to become lightly seized.
