Thread: Me and my bee
Old 10-28-2012, 12:13 AM
2stroker 2stroker is offline
Default Re: Me and my bee
Originally Posted by qwerty2000 View Post
Thanks for replying, I tried both, starting at half choke and tightening the string. It is still slipping after that. Also i noticed a small deformation in the roller . I am not sure if it was there from before or because of tightening.
Still its not starting. I tried to crank up for like 2 mins or more. I ll put the new roller and try again.
Did you try the urethane works alot better..theres a fine line between perfect tension and not. if its perfect it will grab just enough to get you going while your pedaling and then it should fully wind out. good luck friend!
