Old 10-23-2012, 10:06 PM
VIKTR VIKTR is offline
Originally Posted by fatdaddy View Post
You must be using the white wire for the kill switch,(maybe not.) BUT, if so, cap off the white and wire the two kill switch wires to the black and blue wire on yer CDI.(one to each.) If you already have it wired this way then no explaination is needed. If not, just ask around and I'm sure someone will explain why it should be wired this way. Or just get back to me.
I'm not using the white wire... you had already advised me against it
But one or both of the wires were touching the socket I had the switch sitting in. Electrical tape fixed it.
