you are what kind of mileage are you planing per day because you are going to need battery's to match that
100 miles i dont think is going to happen on a Ebike
enough batterys to do half of that distance is going to be $1200
I really am thinking this will be my DD for college. As long as power is good enough for around-town and range will last me a day...
Either way, I think I'd need high range. Probably in the 100 mile range. That is very high though... I'll figure it out I suppose.
You're planning on riding a hundred miles a day with just "around town use" as a "college daily driver"? Are you sure? Have you checked/estimated your actual, average daily mileage?
I could be mistaken, you may have a 50 mile one way commute for all I know lol - but I'm hoping that's a high estimate as honestly, a hundred miles is a bear even on a gasbike. While doable w/o doubt, I've frequently racked up that kinda mileage in a day on my weekend wanderabouts but I gotta tell ya it can leave you whipped - the bike may not care, but you just might, 5-700 miles a week on any bicycle is gonna take a toll on bike, body & soul no matter it's motive method.
If it turns out you've more like sixty miles a day or less electrics can still be economically viable though, with a bit of planning. For example I've about a thirty mile range with my 48v 1000w hub & just the $550 48V 15AH LiFePO4 Battery Pack - so if it's thirty miles or less to the destination, you can simply plug in & charge while you're at class/work/whatever (I'd opt for the 5A Charger over the included 2A)... with the 48V 20AH LiFePO4 Battery Pack you'd have a "buffer zone" of another 10-15 miles or so... BTW, these mileage estimates are rough, based on worst case "no pedaling", stop n'go & somewhat hilly terrain, obviously any conservation efforts would help extend that range... like pedaling from time to time to help take-offs & hills
I'm not saying that an electric would be the "best" choice for you... but it does seem your options are somewhat limited & I just wanted to provide some food for thought![]()
with a 4 stroke its more noticable than a 2 stroke if you go up in size and if you want to ride it as a form of daily transportation you should think about reliability of the 4 stroke engines over the 2 stroke engines these kits its a big difference between the two you may spend more on a 4 stroke kit to start with but it saves in possible down time and parts in the long run you dont need to be waiting for parts when you need to ride to school or work
Not that it matters for me since I'm in the USA, but I have read in other threads that gas bikes (unless they are manufactured mopeds) are not legal even if under 49cc. What is and is not legal should be pretty easy to clarify. If something is clearly stated as illegal then all it takes is one cop who feels like it to give you a hard time, possibly a very hard time. I have heard of some outrageous fines being assessed.
Why put yourself in a position where someone can give you a hard time legally if they feel like it? Especially if there is another route you can go that is legal? (ebikes)
Regarding an electric motorcycle... the heavier it is then the more motor you need to power it. Then you're going to go well over the wattage allowed and draw attention to yourself. If you have a regular pedal bike with gears, relatively small and inconspicuous batteries and a motor that doesn't much look like a motor (I'm picturing the magic pie kit) then you won't draw much attention to yourself and can likely get by with a more powerful motor (meaning more voltage in the batteries).
No bike or motorcycle can be all things. Choices have to be made having to do with budget, legality, practicality and your actual needs vs wants. One good thing is that you have the time to do research, find out for sure what the laws are and the consequences if you get busted, determine a budget and ask a whole lot of informed questions. By informed, I mean read threads and become familiar with your options... then ask specific questions from sources you trust as being accurate. Good luck.
SB
there is only one or two engines you "may get away with calling a 49cc and its the honda GX100 and the lifan 98cc because they "look" like the HS 49cc with a little effort
