Old 10-22-2012, 07:18 PM
nightcruiser nightcruiser is offline
Default Re: Need help with repair
Originally Posted by DaveC View Post
The clutches on these things can be real tricky to set up and can cause the problems your having. The clutch release needs like a preload that's difficult to set and under the cover there's a "star" nut is a cause for problems, too.
If you remove the small bevel gear the clutch is decoupled from the crankshaft, so you can tell for sure at that point if its the clutch or something in the motor that is locking things up....
