Old 10-19-2012, 01:27 AM
shwnrttr's Avatar
shwnrttr shwnrttr is offline
Default Re: tire\chain locks up
if yoour trying to roll it as is in the picture. it will be hard to roll because its trying to turn the engine over. you need to put the clutch actuator arm on.then adjust the slack out of the cable. then pull the clutch in before you try to roll it. hope that helps
There is a fine line between a hobby and mental illness
