Thread: Paint Job
Old 10-05-2012, 12:52 AM
squirrel squirrel is offline
Default Re: Paint Job
What type of equipment do you have? Air compressor? If so do you have a paint gun? Where will you be painting? Indoors? Outside?
My advice would be to focus on proper technique.
You can get good results with a spray can if you take your time and spray light coats. Make sure to let each coat dry . Lightly sand with superfine sand paper. Wipe down with a microfiber cloth doused in rubbing alcohol. Let dry,then spray the next coat.
Repeat as necessary.
Good luck!
