Old 09-19-2012, 03:11 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Oi Mates! - Calvin W. Cline Dover, NH
The rag joint can be tricky, some times the holes don't align. I have had the holes is the rubber pieces drilled wrong also. I would lay the three back plates on the sprocket to see if the holes align, if they do then you can work with the rubber pieces to make it fit. One member has posted pictures of plates that were drilled wrong. Anyway welcome, no one here knows it all but all together we know a lot.
Your results may not be the same,Greg
