Old 09-18-2012, 07:15 PM
digitalgodd digitalgodd is offline
Default Re: Hello from Minnesota
I think I have it figured out. I just needed to make sure my engine was seated tight and correctly to the frame. It seems to be running very well now. I am going to throw a NGK B7HS plug in it with a .25 gap and see how that performs. I also rigged up a Ram Air type setup. I turned the stock air filter on the NT carb upside down so the four little pipes are facing up. I attached a 12" piece of bilge hose and then attached a scoop made from the top of a 2 liter pop bottle. This really helps the top end and take off. I will post a pic of it tomorrow when it is light out and I can take a good picture of it.
