motorbikes
How does a pull starter work? What happens once it turns on the engine?
Anyone have a good set of instructions for re-assembling? I am in process of changing the color of my Greyhound 79cc from blue to black, and I tore the pull starter totally apart to paint the sheetmetal. Problem is, when I removed the nut on the center of the pull start shaft, the whole thing sprang apart. Thus I was not able to see exactly how it was assembled to begin with.
It's magic. Nobody knows how they work.
Hit it with a juju stick.
Works every time.
There are videos on Youtube showing how to install a new spring, that should show you what you need. The flat springs wind very tight into a small circle, very hard to keep flat and concise under the extreme tension. You can make a winding board out of a piece of scrap wood with short nails placed appropriately to help you while you wind the coil and hold it flat. Each spring is different so you just have to experiment with what nails are needed to assist you.
