Thread: chain tensioner
Old 11-03-2008, 01:29 PM
mralaska's Avatar
mralaska mralaska is offline
Default Re: chain tensioner
Originally Posted by noob View Post
is there a downside to going without the tensioner??
Compared to the stock chain tensioner, I have found absolutely no downside to going without the tensioner. In my case, the stock chain seemed to be stretching bad the first 100 miles WITH the stock tensioner but immediately quit as soon as I removed the tensioner. I cannot comment on spring loaded tensioners because I have not tried them.
When I was using the stock tensioner without any mods it was a pain to adjust the chain. After adopting the "T-Shirt" solution posted by MotorbikeMike I found it much simpler to drop in 1/8" shims to dial in the chain length and have not had to adjust it in the 200-300 miles since then. Not only that, but my chain has run quieter and I no longer worry about the chain getting thrown from the sprocket.
Some guys use nuts, half links, or other stuff for spacers but I found it worth the $3.00 strip of 1/8" flat stock from my friendly neighborhood hardware store and about 5 minutes work with a hacksaw to make the T-Shirts:
50cc Slant Head mounted on a $5 Huffy mtn bike
