Old 09-07-2012, 03:54 PM is offline
Default Re: Hello from a Swedish honda 2stroke enthusiast
well my only 2 ideas left are the crank seal is bad or its the cdi.... gonna drain the oil, havent done that in a year since its not been running, but should smell of gas if broken gasket....
as for lean or rich, iv walked through main jets all the way from 52 to 80, standard for a 13mm carb 8mm inlet is 56-65 depending on temperature and altitude, in usa were thay have 16mm carbs and 16mm inlets its 105 main jet size...
