Thread: Schwin StingRay
Old 09-03-2012, 03:57 PM
klapool klapool is offline
Default Re: Schwin StingRay
Originally Posted by tpringle View Post
klapool, thanks for your input. Did you have to shim out your rear spocket more to gain clearance from the rear tire? Hey cool exhaust set up. What about gas tank mounting? Did you make a different mount for that as well?
I didnt shim out the sprocket as the chain ran clear. I did have to cut the rear fender where the chain would have rubbed but it looks like it was made that way.
The tank was a different bird all together as I want straps going around the frame. So I put some washers on the tank mount studs and put the nuts on to keep the washers on. The with a piece of cork gasket material I set the tank on the frame and straightened the washers and welded them to the frame. That way I could get the tank off should I need to. Worked pretty slick!! The muffler set up was my sons idea and I have a thread about that, I'll post it after supper!
