Old 08-25-2012, 03:39 AM
motorbicycling_hunter's Avatar
motorbicycling_hunter motorbicycling_hunter is offline
Default Re: build suggestions for a logging road hill climber
Originally Posted by Andyinchville1 View Post
FWIW - We can go up to about 124T on 1/2 pitch chain....You should be able to climb most anything w/ gearing that low!.....Actually, you'd probably run out of traction or flip backwards first.
thanks Andrew, that's excellent.
the plan is to ride up the hills and quietly [no engine running] ride back down them.
2 stroke is also a good route, simpler and more angle resistant [no oil pan]. can always upgrade to higher 2s quality motor later.
there is also the possibility of towing a small trailer.
