Old 10-29-2008, 03:25 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: How do you detect air leaks?
Around here somewhere is the specs for that torque but are you sure it isn't coming from around your spark plug. If you have had the plug out several times it might be the compression gasket on the plug gone. If you haven't had it out and it is tight, then it might be the head gasket. More likely the plug I think
