Old 08-06-2012, 06:37 PM
Pilotgeek's Avatar
Pilotgeek Pilotgeek is offline
Default Re: Starting from 0, need some advice
Originally Posted by scubaru89 View Post
I should probably also mention I am going to school for Manufacturing Engineering and have full use of mills, lathes, CNC Mills/Lathes, wire EDM, etc etc. So if it needs built, I should be able to do it myself for small fixes and adjustments.
Whoa, if you have access to that kind of equipment, you will be able to do more than "small fixes and adjustments". Even if you need to rig up an entire custom mounting system you should be good to go.
