http://en.wikipedia.org/wiki/Hydrostatic_testBe very very careful trying this. Unless you have a good understanding of metal, welding and the pressures you'd be working with, you could be injured. Hydro forming metal is a job best left to those with the knowledge and the proper equipment. Simply pumping water into a closed vessel without careful engineering could produce a very effective 'pipe bomb'.
Has anybody made a tank or know of a tank made using the 2 stroke expansion chamber technique of blowing? You weld 2 flat pieces of steel together along the edges and then pump water in until they balloon outwards. You can get some very swoopy shapes that way.
I could definitely see welding up an xchamber and then pumping water to get it to round out a bit. I could most easily see this done to make neat looking gas tanks, though.
I've never heard of expansion chambers being formed in that way. You want the dimensions of a pipe to be very precise, something not possible by pumping water in between a couple of welded plates.
Most OEM chambers are made two halves of stamped sheet metal that's been welded together like this -
And most aftermarket pipes are constructed from rolled cones and bent header pipes, again welded together -
Whoever told you that water forming fairy tale was just making things up to see if you'd believe them.
So what happens when part of the pipe you don't want to change balloons out and you've lost your dimensions? Not to mention the thousands of PSI you'll need to actually bend metal. Sorry, but while this alleged forming technique may work in Internet Fantasy Land, it worthless, expensive, and dangerous in the real world.
Trust me, I can't answer for 2 strokes in America but, in my racing, blown pipes are entirely ordinary, and the same applies across European countries. OK, if you need to change direction or angle somewhere you will have to cut and rotate the sections, but you get far smoother shapes far more easily than with welded up rolled sections.
There is a downside though, in that harmonic cracking can occur, where the fracture actually goes at an angle through the pipe, like glass breaks. It's effectively impossible to repair when it goes like that.
Here's the way it's done: http://www.3wheelerworld.com/showthread.php/95083-How-to-build-an-expansion-chamber
I think the hardest part would be knowing what shape to cut the peaces of metal before shaping them.
