Thread: gears
Old 07-28-2012, 12:13 PM
2door's Avatar
2door 2door is offline
Default Re: gears
Dry silicone lube is not enough lubrication for the gears. You really need something a bit more like grease. As was warned above, not too much. A "Q-Tip works well for applying it and you don't need more than a 'Q-Tip will hold. Spread it evenly over the gears.
Dry silicone has its uses but not for gear lubrication.
