Old 07-14-2012, 08:17 PM
Bernie Bernie is offline
Default Re: gear puller clutch removal tool
Both of my kits didnt have on in it.
Is this a tool you can locally. Either a auto or home store. We have a harbor freight here to I had called them but probably didnt say what I needed right idk. I will have to print off a picture of it and take it and hunt one down. I know the motorcycle store would have one but they are not open again till Monday and I wanted to have this together by then.
I have it all apart up till we didnt have the tool to use. Had absolutely no lube on anything in it that I noticed except for the piston. Paint chips and dirt on the inside of it. Pulled all of my studs and they all were filled with shavings. And that flat head screw on the small gear came off with my fingers. Wasnt even tight at all.
Thanks for the replies by the way
