Old 07-13-2012, 11:36 PM
bigbutterbean bigbutterbean is offline
Got my new headlight from wonderful creations on ebay today and installed it. It has a built-in voltage regulator, so I'm running it off the white wire with a toggle switch in between. I don't really like the mounting position I chose as much as I thought I would, so next chance I get, I will use the clamp it came with to mount it on my handlebar stem. Other things I dod today were adjust my rear axle and bottom bracket and make a support to keep my improvised saddlebag out of my spokes. The spokes were rubbing it a bit and giving me a wobbly feeling at high speed. I also put the original coaster brake clamp back on. I previously had used it for another project that I no longer needed it for, but didn't realize I still had it lol. I was using some cheap aluminum strapping on the coaster brake arm that was starting to bend, so when I realized I still had the original clamp, I decided immediately it was going back on. So that's what I did today, lol.
