Old 06-25-2012, 08:28 PM
Longshot270's Avatar
Longshot270 Longshot270 is offline
Default Re: Regular with up to 10% booze-a-haul, or high octane w/out?
Originally Posted by DaveC View Post
The higher number means it burns slower. Gasoline actually burns too fast for hi-compression motors and is not resistant to pre-ignition. That's why if you put regular gas in a hi compression motor you get "ping". And the additives needed to slow down the burn cost more so the the price for hi-test premium is higher. Alcohol has a hi octane rateing which is why it's used for racing, it just takes twice as much alcohol as gas. Air/fuel ratio for gas is 14:1, for alcohol it's 7:1. A not-so-cheap way to raise octain rating is to add tolulene, a paint thinner, to the gas. Tolulene has an octane rating of 117 which is why it's added to gas now. When they first cut-off tetra ethyl lead for use in gasoline they needed something to raise the octane and tolulene is one of the things they used.
Originally Posted by Bikeguy Joe View Post
Been running gas-o-hol for years in everything I own, no problems.
Why waste money on high octane gas when it has no added performance value?
Where do you live? I've heard that some areas have fuel that isn't as problematic.
