Old 06-03-2012, 07:09 PM
thegnu's Avatar
thegnu thegnu is offline
Default Re: Soda Blasting,Anyone?
Originally Posted by DaveC View Post
Soda blasting is considered "green". Sandblasting carries the risk of silicosis if you breath in too much. When I did it I had a supplied air helmet. The pressure inside prevents the sand dust from entering. While you don't need it for soda blasting it's a good idea to use the best dust filter you can find, the really good cloth/fiber one. Not a cheapie dust mask, an expensive dust mask. That and a face shield and your good to go. When you finish soda blasting use air to blow all the dust off and prime as soon as you can. Blasted surfaces start hazing with rust fast.
soda is too soft a blasting media to remove rust an scale , but for a nice gentle blast job with out putting too rough a profile on the surface soda is the way to go . I have had a couple corvettes soda blasted pryor to restoration an it didnt even damage the jellcoating .
four wheels move the body . two wheels move the soul
