Old 05-09-2012, 07:58 AM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: Magnetize a spoke
Originally Posted by allen standley View Post
Is there a method that will magnetize one spoke so the speedo transmitter can see it. I've thrown sensors off the wheel so often there's got to be a better way.
Nothing permanent unless you remove the spoke first. I magnetize my screwdrivers with this.,s:8,i:124
If the spoke is placed into the center of a coil of wire, and then a large amount of DIRECT CURRENT is sent through the wire, the item can be magnetized. The orientation of its poles will match the orientation of the field generated by the coil.
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
