Thread: Clutch help
Old 04-30-2012, 01:06 PM
fx-2's Avatar
fx-2 fx-2 is offline
Default Re: Clutch help
So you have the complete picture . This motor was disassembled new bearing new gaskets an seals . The only work on the clutch was the bucking bar was polished on both ends and a small radius put on cam end I mean very small 1/16 R maybe . The cam surface was polished . Ever thing was cleaned with solvent then final cleaning with brake cleaner on assembly That's all . And red grease on the bevel gears not a lot . I check the other thread not much help . Thanks for all the help . Dan
