Old 04-29-2012, 08:43 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: WOW ! I thought I was on my own...
Dougy you asked about spark plugs, NGK runs the best in both of my engines. Most members here run the b6hs, I run the bp5hs which is one step hotter with the extended tip. I bought a champion that interchanged from b6hs and it ran very bad, I put the old plug back in and it ran normal again. The link below will help you get her going. Good luck
Your results may not be the same,Greg
