Old 04-28-2012, 12:29 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: What else do I need for the install?
Originally Posted by DrewFL View Post
I know the JB won't hold any of that. It looks like I will have to extract it. Do you know of any good links on how to do this the right way? I have seen it done but never have attempted it myself. Also, what size easy out and drill bit will I need?
1) Remove engine, hard to work on while installed. I'd remove the cylinder. I made a jig to use in my drill press. This will work for both exhaust and intake studs.
I use 6mm X 1.0 long studs in the intake to hold cylinder in place. The cut away on the bottom is for the washer and nuts.
2) Take a center punch and punch stud as close to the center as you can.
3) I'd start out with a 1/16" drill bit, and move up. Work slow as the smaller the drill bit, the easier it can snap. Use cutting oil, or just oil if that's all you have. I have cutting oil, it's the best.
4) Then I'd use a "left handed" drill bit to see if that would work.
5) Drill as large as a hole that you can, paying attention to the angle of the hole. Drill a straight hole.
6) Use the biggest screw extractor that you can.
7) Tab extractor into the hole.
8) Turn extractor same as you were removing a bolt or stud (counter clockwise).
9) You might want to use a little liquid wrench or PB Blaster before trying to remove the stud.
10) If it won't come out.
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
