Old 10-14-2008, 11:02 PM
jerseykat1's Avatar
jerseykat1 jerseykat1 is offline
Default Re: Proper Break-in and Making your engine last.
Originally Posted by Cr9ck View Post
whats the benefit to replacing the wire and sparkplug? do you get more power or what?
easier starting, i am sure you will gain a bit of power, but in my opinion it is mainly so that you can purchase and use a digital (bell brand or other brand) speedometer, if you attempt to use a digital speedometer with your stock plug wire it will cause it to constantly reset and drive you crazy. The plug wire is a cheap and easy upgrade **** you could go to a local repair shop or junkyard and get a used plug wire, it will still be better than whats there now.
