Old 04-26-2012, 02:33 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: What else do I need for the install?
Originally Posted by DrewFL View Post
but the clutch lever on the motor case seems really loose and swings back and forth with no effort. Is this a sign of something broken inside? or is this the way it is until I hook up the chain and everything? Thanks again
It's not the tightest fitting part, it should be fine when the cable is hooked up and both the cable and clutch adjusted as needed. Make sure that the bucking bar and ball are in the clutch shaft under the left drive gear cover. The ball goes in first.
Courtesy of
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
