Old 04-18-2012, 08:10 PM
5-7HEAVEN 5-7HEAVEN is offline
Default Re: OCC Schwinn 4hp issues NEED HELP
The cheapest fix:
Keep the 3" crank pulley. Replace 2" jackshaft pulley with a 6" pulley.
6"/3" = 2:1 ratio.
Replace 20t jackshaft pulley with a 10t pulley. Keep your 36t or whatever rear sprocket.
36t/10t = 3.6:1 ratio.
2:1 x 3.6:1 = 7.2:1 gear ratio.
Your bike should move well.
Unsure at what rpm that the jackshaft clutch will engage.
The simplest fix:
Replace 3" crank pulley with Maxi Torq clutch w/10t sprocket.
Replace 2" pulley and clutch with 20t sprocket.
20t/10t = 2:1.
Install 10t on right-side jackshaft; keep 36t rear sprocket.
36t/10t = 3.6:1
2:1 x 3.6:1 = 7.2:1
No jackshaft clutch to worry about.
Bike will move quickly.
