Old 04-11-2012, 04:24 PM
halfevil333's Avatar
halfevil333 halfevil333 is offline
Default Re: finally, a new project....
ok, so here is some progress and a teaser...
made some bearing cups out of 3/4" INTERNALLY THREADED pipe coupling, got two out of each 6" piece with enough left over to work with for cutting purposes, then drilled out the inside using a step-up bit to 7/8" inner diameter...
and here is the drawn plan for the rockers... based on the harley springer design...
