Old 04-02-2012, 10:07 AM
DFlanagan's Avatar
DFlanagan DFlanagan is offline
Default Re: How Fast are You going? - I wana know
Originally Posted by Easy Rider View Post
Yeah, it's good coming out of the corners and off the line.
I'm using 24" wheels with extra wide rims.
I just got my Morini broken in along with the clutch (5 tanks of petro later). I only get a hour of ride time per tank 2.4 liter (@ WOT!) I have 26" wheels on mine with a 52 tooth rear sprocket and my motor raps out going up hill! (approximately 50mph) It acts like there still some hp's left in the Morini @ max rpm. If you no any "tricks" to setting these motors up let me know. I ordered a 21mm Dellorto carb with piss poor results. At this elevation (7500 ft) there's not enough oxygen in the air to benefit from a larger carb. Even if you go with a smaller jet. My 19mm Dellorto carb is dialed right into the sweet spot. NO throttle hesitation at all. Just rocket like results! LMAO
