Old 03-29-2012, 03:44 AM
Ted Ted is offline
Default Re: Silicon for sealer
It will take Hi Heat if it's the type that will, it should be a gasket making RTV (room temp vulcanizing), it will take very hi heat. If you make a new gasket using RTV **lightly** grease the engine and cover so it won't stick, put a small bead and lightly tighten it so that it's not seated, let it set and then tighten it down, you will end up with a gasket that will never leak.
