Old 10-09-2008, 08:03 PM
trackfodder trackfodder is offline
Default Re: Pull Start / Centrifical Clutch ???
Can you torch an "S" into the crank to buy your clearance? alternatively, replace the crank with a straight shaft pin-on lever type, lengthen the ends, clip the peddle-side lever to carry the sprocket only, and mount 2 levers for peddling outboard
Keith (trackfodder) Williams
