Old 03-20-2012, 11:44 PM
truckd's Avatar
truckd truckd is offline
Default Re: Firmstrong Urban Man (from BeachBikes) Good bike to motorize?
Oh! by the way what are you going to connect the motor to if not a drive sprocket, you will be able to use the 3 spd but only to peddle and once you connect the drive chain to the drive sprocket that in-circles the rear hub you may also use the 3-spd to shift gears while driving
do some research on the whole motorized bicycle thing it might help you understand a few things about how everything works together.
